Minimum practicable linear actuator stroke
Hello everyone!
I'm working on some mechanical system which requires linear actuator to be set in motion. Motion limits are narrow and my first study therefore produced the required stroke of an actuator of about 1 mm. I guess it is too little? Shall I take care to increase the required stroke? Or is it practicable and I will actually be able to successfully control it with 1 mm motion? If not, what is the recommended minimum stroke? The system is light and doesn't require powerful actuator.
RE: Minimum practicable linear actuator stroke
Peter Nachtwey
Delta Computer Systems
http://www.deltamotion.com
http://forum.deltamotion.com/
Look in Laser World Magazine if you want high accuracy small movement platforms.
Keith Cress
TTFN
FAQ731-376: Eng-Tips.com Forum Policies forum1529: Translation Assistance for Engineers
