Updating Userform TextBox Default value
Hi everybody,
I want to know if there is a way to update a userform text box default value when user enters a string in the related field, i.e., every time user runs the macro, the default values should be the last ones user's entered in the previous run.
Thanks in advance
Thanks in advance
RE: Updating Userform TextBox Default value
however, thank you for your follow-up "itsmyjob".
