Ackerman angle with wheel alignment
is there calculation for ackerman steering angle with wheel allignment modification?
RE: Ackerman angle with wheel alignment
Yes, but unless you are running crazy amounts of toe the differences are not significant in an engineering sense, since you probably don't know what your ideal Ackerman is. Near zero steer the toe affects the %Ackerman a lot.
So it really depends on what you want it for. The best discussion of ackerman and turning circle I've seen is is Reimpell and Stoll.
Cheers
Greg Locock
My understanding is that if you don't do any physical modifications to the suspension and steering system, then adjusting the alignment doesn't appreciably affect the Ackermann.
For example, adjusting the camber or toe doesn't affect the Ackermann, but bending the idler arm does.
