Welds paint
Welds paint
Dear friends, what methods do you use to prepare metal structure welds and struture edges before painting? At many projects when mechanics had only used metal brush rust appears after a short time. Do you advise chemical cleaning?
RE: Welds paint
RE: Welds paint
RE: Welds paint
I’d ask some of your paint suppliers what they want you to do. We usually used sandblasting in the shop, as Hokie suggested. At least scrapers and wire bushes, etc. to get rid of all loose scale, etc. Solvent cleaning if grease and oil, and the like existed. Chip off slag, weld spatter, etc, from the welding process.
