Invalid symbol 'sdXX' Found.
SO I came across a new error that I had not seen before (had to be on friday).
I created a model of a prototype, and when it worked I wanted to roll out a family table based on the prototype for different size parts.
The prototype was made with relations controlling hole patterns, but when I created the family table I deleted the relations since the family table would not be controlling the hole patterns.
BUT!
one of the deleted relations is still showing up when I check the family table instances.
It is displaying
Line 2 Section of model RE-750198-01::Invalid symbol 'sd17' found.
and the sd17 inside of the extrude does not even exist anymore, but its still showing up.
I checked in the section relations, in the top level, and the previous relation controlling sd17 is no longer there.
Any ideas?
BUT!
It is displaying
Any ideas?
RE: Invalid symbol 'sdXX' Found.
I looked in all the features and I cant find sd17 anywhere.
Its not causing my models to fail, but I just hate that its showing up
Section
Feature
Part
I would also look in Program to see if the relation can be seen there as well as Model Info.
Are you sure you got rid of it? Check in the instances as well.
I will double check, maybe it is in the extrude level.
I hardly ever use Program, but its possible as well.
I found the relation, it was in a completely different section that the section with the relation referenced. Not sure how it turned up there, very weird.
Thanks for the help!
