shell mating in solidworks
I have modelled structural members using Gauge Pipe in solidworks. When opened it in ansys it shows as a solid files.how can i convert the whole assembly structures into shell or used to redraw it.
Is shell mating possible in solidworks?
Kindly give the suitable suggestion in it.
thank you
Karthikeyan
thank you
Karthikeyan
RE: shell mating in solidworks
Chris, CSWP
SolidWorks '16
ctophers home
SolidWorks Legion
However the other question I have is did you make an assembly or did you use the weldment option in SW. If you didn't then maybe you should have done it like that instead. Then you wouldn't have to convert an the assembly. I don't think what you are talking about on the "Shelling" can be done, but you can convert an assembly to a part. To do that do a file\Save as and change the type to a part.
Scott Baugh, CSWP
FAQ731-376: Eng-Tips.com Forum PoliciesGryphon Environmental
www.2gryphon.com
