node set in the .inp
Hello
please i create a notde set and i would like to use it in an identficiation of parameres i would like to see the name of this set in the .inp file how can i do it because if i create the set i ccan not find it in the inp file can any one help me thanks in advance
RE: node set in the .inp
any help please
I assume you define the set in A/CAE?
With CAE these sets are written into the .inp, beside you made a mistake and defined it on nodes that doesn't exist anymore. But when you've used geometry, you'll find these sets a node and element sets in the .inp.
