Container Yard Design
I've been asked to design a container yard, similar to those made on big ships harbours where containers are stacked one on top of the other, but mine is relatively on small scale. Analyse for piling of containers, I'm planning to perform linear static analysis of rigid beam/plate/shell resting on Winkler spring and this will be designed as RC concrete slab on grade.
It seems that governing case will be the maneuvering motions (twisting, torsional, warping of wheels) of stacker during loading and unloading containers, so slab on grade will be subjected most extreme loads during that case I believe. But I'm puzzled on how to perform that analysis (twisting, torsional, warping effects) of stacker during maneuvering, is there any standart analysis type that I need to perform?
Aside from all of this, client requires to apply the asphalt layer on top of the concrete, thickness of that asphalt needs to be determined and again I'm afraid of that stacker motions will play an important role in this scenario as well, too thin asphalt layer might be unbounded from Rc slab on grade, too thick asphalet may cause submerging effect etc..
I'll appreciate your guidance.
RE: Container Yard Design
I do know from a pavement design class that ship yards often have proprietary pavement designs which sometimes involve high grade asphalt running surface with highly designed/researched thickness on various subgrades/bases. But this isn't something we can talk about online in detail. :)
Voice the concerns to the client and your recommendations. If they don't back down ask for an example of a project that this was done and it performed well. Design concrete as if asphalt wasn't there for loads.
Since there is such an unrealistic requirement on concrete, about as useless as the driveway "sealing:, maybe they will accept painting the white concrete black with the stuff that home owners get for their newer looking asphalt pavements. Much less in the way of problems to deal with later.
Dave
Thaidavid
Many container pavements are now done with roller compacted concrete as Dave noted. They are not reinforced and their durability for the turning/abrasion you noted is very good.
I would change the analysis approach you are using. It is a pavement. It can be designed as any other rigid pavement, just make sure that you get the material properties of roller compacted concrete and not conventional portland cement concrete. There are some excellent publications available on roller compacted concrete, and you can use downloadable software from the US Army Corps of Engineers for the analysis. It is a modified elastic layer analysis program. Google "PCASE" and get the latest version. While it is primarily geared to military equipment, there is also information in the database on container loading equipment as well.
If you want to do the entire analysis by hand, look at the Portland Cement Association's rigid pavement design methods (based on Westergaard). I am attaching a paper that might help you. It is directly related to roller compacted concrete design for container applications.
Also, if you want to know more about roller compacted concrete, one of the leading experts in the US is Dr. Shiraz Tayabji. Google him. He is located in the US, in Maryland.
