Two bundles one tower
I have a tower with two bundles that are on the same circuit. The problem that I am running into is that the relaying under reaches for a fault on one bundle due to the parallel flow on the other bundle. This has to be a problem that has been solved a long time ago. Do you usually just put more margin into your settings? Is there no nice solution? Am I just use the wrong terms and that is why I can't find anything on this?
RE: Two bundles one tower
