Does Weldable A706 Have Same Yield and Tensile as A615?
Does weldable A706 rebar have the same 60,000 psi yield and 90,000 psi tensile strength as A615?
I currently do not have the necessary ASTM literature to determine this and must produce a design right away, as usual.
Thank you!
Thank you!
RE: Does Weldable A706 Have Same Yield and Tensile as A615?
According to an ACI detailing manual, A706-84a has a tensile strength of only 80,000 psi as opposed to the 90,000 of A615-85.
So what do the second numbers, -84a and -85 refer to?
Also, it seems apparent, through research, that A706 IS INDEED "weldable rebar". Will someone please confirm?
Thank you!
Yes, A706 bar is weldable bar.
