Recovering AB masters
I have a desktop with several Rockwell activations loaded. I foolishly changed the hard drive from FAT to NTFS. This action disabled all of my RS software. I can no longer run the software, nor can I move the activation from the hard drive. Does someone know a resolution?
RE: Recovering AB masters
I have had to do this in the past.  Rockwell allows you to reset the activation via the internet.  just go to:
http://support.rockwellautomation.com/resetcodes/
there you will find instructions as to how to reset your activation.
you will need your master disk(floppy) to complete the task.
eln
