Detail Arc
Detail Arc
Detail Arc
Not sure when Detail Editing changed. But, you could use to double click on the detail arc that is around the area you want to detail. And, then, you could change the position and size of the arc. Is this still available? Or, did they get rid of this function?
Richard
RE: Detail Arc
What version of NX are you on?
RE: Detail Arc
I'm on NX 9.0.
RE: Detail Arc
To change the boundary location or size, RMB over the boundary -> Boundary -> pick center point (if moving) or boundary edge (if resizing) and release RMB (don't hold the MB down) -> adjust boundary by dragging
"Know the rules well, so you can break them effectively."
-Dalai Lama XIV
RE: Detail Arc
The process has changed a little. Right click on the detail view and choose "boundary"; click on the circle in the parent view to resize it (the first click will give you a "rubber banding" circle, the next click will set the size) or click on the center point to edit, 2nd click to set new point location.
www.nxjournaling.com
RE: Detail Arc
Thanks all! That works! Sorry, I haven't been on UG for a while. Thanks for getting me up to speed on Detail Views!
