COMMON ZONE MODIFIER - DO I NEED IT?
Afternoon
This may sound like an utterly stupid question, but I've never used the 'CZ' modifier, as most surface work we do is usually controlled with a surface profile tolerance. So it got me thinking, if I have a plate with say 4 pads sticking up which are cut to a surface, what's the difference between using surface profile tolerance, and a surface profile tolerance with a 'CZ' modifier? I can't personally see any difference in the end result?
Or am I missing something
Thanks in advance
Thanks in advance
RE: COMMON ZONE MODIFIER - DO I NEED IT?
If you use Profile without datums, it applies to every feature separately due to Independence principle. Then you have situation like the one shown on enclosed picture.
Not everybody likes it this way, but it's there.
Thanks again
