CSIbridge nonlinear analysis for a step in moving load case
I require a nonlinear analysis for a vehicle at a position on a bridge. Nonlinear analysis because the model has nonlinear gap and link elements. I cannot carry out a NL analysis using statics multi-step analysis, and I do not want an influence surface analysis using a moving load analysis. Could someone suggest how I go about doing this?
RE: CSIbridge nonlinear analysis for a step in moving load case
Either of this two:
Define NL deal load case and then start your ML case from the stiffness of NL dead load
Or Use Time history analysis with small time-steps again with stiffness from NL case.
Your stress-strain curve can be either default in CSI or can quickly make your own points from theoretical or experimental data.
Shoot for the Moon, even if U miss, U still land among Stars!
