Negative pressure 30L barrel
Hi
I am designing systems for emptying latrines/toilets in Kigali (full thread on the problem here: http://www.eng-tips.com/viewthread.cfm?qid=408959 and video of process here: https://www.youtube.com/watch?v=5S_8mLChMe4)
We pump the waste out from the underground pits using a vane pump to a 50L vacuum proof container- we then pour that into a 50L thin walled chemical container to carry to roadside transport (we only half fill so they can be carried).
I'd like to eliminate this pouring step and empty direct to barrels we can carry to the roadside. Barrels plus waste will need to remain <30kg for easy of carrying. Is there any way I can design a barrel that can withstand ~0.5-0.7 bar and still be convenient to carry to the road? Ok if its expensive - we have money for capital costs so we can import.
Nicola
Nicola
RE: Negative pressure 30L barrel
Obviously you don't need the pump - be it manual or powered - but the tank and backpack harness might be a good start.
There is obviously a difference between holding positive pressure and a vacuum, so you'd need to look more closely.
Or you could look at backpack wet & dry vac (vacuum) but again you don't need the pumps etc.
However, I have what I think is a better idea I'll post in your original thread.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
