ANSYS modelling of frame
Are there any tutorials to perform modal analysis of RC or steel beam-column connections in ANSYS? I only want to model the beam-column connection or a frame and not the entire structure. When doing this, since the mass is less, the period will be very high, what is the solution for this? Thanks!
