Extruded Cut from a Curved Surface Failing
Hi guys, I made the bottom of my part curve very slightly using the Flex feature, but now I am unable to Cut Extrude from it.
Basically I want to make a cut 1mm offset from the edge on the bottom face, 1mm deep. So it forms a lip around the bottom.
Selecting the curved face as my "Surface/Face/Plane" gives me an "Unable to create this extruded feature due to geometric conditions" error.
Not sure what I am doing wrong. Any help is appreciated!
RE: Extruded Cut from a Curved Surface Failing
You always need to select flat surfaces since this is where the sketch is build on.
Steve R SWCA (Solidworks Certified Associate)
http://www.3dlogix.com
https://www.youtube.com/user/3dlogix
http://www.sprdesign.com
Move your flex feature to after Fillet2
Then drag the bottom bar of your feature tree up above the new flex feature location
Now create your cut-extrude, before your flex feature.
The only issue I had was the depth of the cut, could not go 1mm like you had it, it cuts completely through the boss extrude and causes the loft to crash.
