Retaining Snap Rings For Slotted Nut
RE: Retaining Snap Rings For Slotted Nut
It looks similar to a standard type E radial retaining ring:
https://www.rotorclip.com/cat_pdfs/de.pdf
But I think it is a custom design. Easy enough to be made, try Rotor Clip, Seeger-Orbis, Smalley, RingMasters, etc.
It doesn't look standard, though.
If you need a bunch of the exact same ring,
make a spec drawing and fax it to everybody.
Whoever quotes it cheap with no tooling charge, already has the tools.
Mike Halloran
Pembroke Pines, FL, USA
Maybe I should have posted in "Hobby" as a friend only needs a couple. It is used in a parking brake actuator for 70's car. I was hoping it was a DIN/SAE standard I had never encountered
CoryPad, notice the ID is the circle but the "key" extends to prevent rotation of the inner castle nut.
Try RockAuto.com.
Mike Halloran
Yes, I am familiar with the style, we used it at GM over 15 years ago.
Is there a “description” different than what I am calling it that could help locate them?
post make, model, year, please
while finding a part to use is part of the search, my inquiry was more for defining that type of part.
in this case, the clip was used in Girling rear calipers w/park brake, from early 70's deTomaso.
Here is a link where a new one can be purchased
http://www.dinoparts.eu/EN/fiat-coupe-spider-2400/...
But, I am still interested in determining if a generic part.
This is likely a special/OEM.
