Roundness and plumbness
Dear experts,
We are building the tank with Jacking method. The top shell course will be erected first on the temporary supports.
The third party inspector keep asking me to check the roundness and plumpness of this top course after fit up and after welding and use the tolerance as specified in API 650.
I am arguing with the inspector since API 650 clearly stated that roundness is check the radius of the tank measured from the center of the tank to the shell 300 mm above the corner weld. Plumbness is checked from the top shell course to the bottom shell course.
If we want to check the plumbness of individual shell course we need to refer to ASTM A6 or ASTM A20 as stated in API 650 about the same.
We did check the circumference of the tank and its about 18 mm above the theoretical circumferential.
Any comments ?
Any comments ?
RE: Roundness and plumbness
The third party inspector is not getting confused with peaking and banding is he ?
DD
No the TPI is fully understand about peaking on vertical joint and banding on horizontal joint.
I am agree with JS, those tolerance shall applied after the whole tank shells are completely erected and welded before hydrotesting.
This point also been addressed to the TPI. His concern is how to ensure the final stage will be meet tolerance if we are not checking every shell course during erection.
API does not addressed the radius tolerance on each shell course. API does address how to measure plumpness on every shell course by referring to ASTM A6 or A20 whichever applicable.
Ask him to provide you WHAT information would satisfy him THEN ask him to reference some or any tolerances for a tank built via this method. It's not black and white. At the end like previously stated the final result is what counts.. unless some moron put a hold on the ITP for each course being put up. Then I'm sorry.
