NXOpen get component connection routing mech
Hi all together,
i try to find a solution to get the component is connectet to a routing object.
I played arraund with Segments, Isegments, stocks,connectionpoints and routing manager.
At the moment i use a attribute for each... to identify the flange, sleeve or t-peece.
Is there a better solution to get it working?
Thanks Hagen
I use NX 9 with TeamCenter
Thanks Hagen
