Restart analysis
Restart analysis
Hello, I am going to restart analysis, I have added some local coordinate systems in the newly created step, but now I get the error message when trying to write the job:
"Since the current model is being used for restart analysis, the CSYS transforms for the following newly created attributes will not be written out: lower tool 1 (BC), lower tool 2 (BC)"
Does this mean the BC's with reference with the newly created coordinate systems will not be active in the current job, or does it simply mean not all the information from the transform will be logged?
Hopefully someone will be able to help me out here. I would like not to run the first step over again just because I need the coordinate systems added.
Best regards,
Andreas
Best regards,
Andreas
RE: Restart analysis
Why don't you do the transformation in the initial analysis?
Otherwise try it with an inport analysis.
