pH vs Chloride
pH vs Chloride
what is the relationship between pH and Chloride when it comes to corrosion?
RE: pH vs Chloride
Want to know more? What material are we talking about? What else is in the water, other than H+, OH- and Cl-? What temperature range?
RE: pH vs Chloride
Don't believe that there is a relationship between pH and chloride. Chloride is an ionic compound usually associated with sodium in water which does not affect the pH. However, when chloride is associated with hydrogen as in hydrochloric acid, the pH will be lowered.
RE: pH vs Chloride
David Simpson, PE
MuleShoe Engineering
In questions of science, the authority of a thousand is not worth the humble reasoning of a single individual. Galileo Galilei, Italian Physicist
