eDrawings viewer -- change line width
since I am on a high resolution screen, I'd like to change the line width (make lines thicker) for the display in eDrawings viewer.
(How) is this possible?
Thanks for help,
David.P
RE: eDrawings viewer -- change line width
Edrawings is viewer only... so changing line width would have to be done on your original file. To change the width, check out Draftsight, however users are no longer just viewing the file now.
Scott Baugh, CSWP pc2
Gryphon Environmental
www.2gryphon.com
Quote:
"If it's not broke, Don't fix it!"
