rename node text
rename node text
morning, i am just graduated engineer,I start learning SAFE and soon etabs,,
I want to ask about some small tips like
i set builing layout and arange the columns and i safe it so every floor i import i import it on that col file so i dong have to set the column and to make it eazy to sum the columns loads, i want to rename it "node text"' in reactions from detailing option to make it easier to use it with columns ,
thanks.
thanks.
