Slab to Jumpformed wall connection using centrally located inserts
thread507-319174: Slab to wall connection using inserts or pull-out bars
This thread is a continuation to the thread above.
I have designed the slabs as simply supported and want to connect them to jumpformed wall using central inserts.
Do I need to use equivalent number of centrally placed inserts to match my bottom bars? What do I need to check here?
Thanks in advance
