B axis invert
B axis invert
We keep getting this alarm. I finally pulled the b axis motor and it seems very stiff to turn by hand. its a Fanuc A06B-0115-B103. Does anyone know if that is normal?
RE: B axis invert
RE: B axis invert
Z axis Excess
RE: B axis invert
If the alarm happens all the time, I would pull the motor and run it back and fourth in manual mode and see if it behave the same way.
If it's on the FO-NT, it could be debris in and around the lens assembly area that's binding things up.
Also, there is a red anodized aparture under the lens cartridge that can come loose and bind things up. Pull the cone off and make sure it's in all the way.
RE: B axis invert
RE: B axis invert
RE: B axis invert
If that is okay, it's possible that the power wire that goes to the motor is broken somewhere.
I understand your concern about the servo amplifier. It is a possibility, but in 17 years, I have only replaced a couple of them, usually it's a problem with the encoder side of it.
RE: B axis invert
RE: B axis invert
Did you say you unhooked the motor? Is it possible that your back up battery has gone bad and lost your b-axis ref. point? I had this happen as well on our FOM23015NT.
