Show regions where the von mises stress is above 250 N/mm^2
Hi All,
How can I get stress plots only on regions where stresses exceed 250 MPa?The regions below the stress value of 250 MPa should remain gray.
Rgds
Shindey
RE: Show regions where the von mises stress is above 250 N/mm^2
Options -> Contour -> Limits -> Specify whatever min/max limits you want
Thanks Dave442.
