ECUADOR EARTHQUAKE BUILDING DAMAGE TEC QUESTION
Hello all I am a volunteer construction advisor. All ecuadorean architects and engineers recommend to install 40cm long steel rebar segments on side of columns(see image). My trip to the town closest to the epicenter showed that this practice is a complete failure. Any suggestion is welcomed.
RE: ECUADOR EARTHQUAKE BUILDING DAMAGE TEC QUESTION
Was there a wall there and it was used as a brace for a moment frame. I don't know if Ecuador is a high seismic zone, but that shouldn't be permitted where you have that such an irregular building that would obviously cause torsion in the building, not to mention that those columns see very slender for a highly seismic zone.
Middle column also doesn't show closely spaced stirrups [as req'd by most codes] it shows 1 from what i can see if i zoom in, at it doesn't to be larger than a #4 bar?
were the rebars embedded in concrete ties? Maybe the 40cm rule has to do with the anchorage length of a rebar with diameter 8mm to 12mm in concrete (old codes in Eastern Europe specified an anchorage length of 40 times the rebar diameter).
This technique is used sometimes in the Balkans, in Europe (I have to mention that Balkans is a highly seismic region in Europe). Unfortunately, in most cases the use of this technique is erroneous. The only case in which this technique would be considered correct is when the designer has actually considered the effect of infill walls. In the Eurocodes you have specific provisions for masonry infill frames. When you analyze a such building, you have to consider some diagonal struts (i.e. the masonry wall) attached to the nodes of the main frame. You calculate an effective width of the strut, an effective stiffness and then you run the analysis. Nevertheless, there is debate in this field and research is still actively going on. Depending on the position of such infill walls in the structure, they influence the fundamental vibration period of the structure and they may induce considerable torsional effects.
As a conclusion, I would say that this detailing does more harm then good, unless the designer was well aware of the behavior of masonry infill frames.
I am sorry, I didn't get your comment. I asked you whether the 40cm bars were anchored in a small concrete tie (or call it strip, or belt or something else). I didn't mean to include foundations issues in this discussion.
Specific to this photo:
1. Columns for seismic (and everything else) should have 4 bars and column ties for the full height.
2. Out of plane buckling on the masonry wall needs to be resisted with reinforcement (ladder type in the joint or bond beam every 4 ft in height). Developing a rebar into "really good mortar" gets us this photo.
3. There is another practice of using a foam core wall with welded wire reinforcing sheets (electromalla) plastered onto the inside and outside faces to create the infill panel. I am not a fan of "really good plaster" either, but this would at least give some diagonal tension capacity to the infill wall.
Some highly seismic places like Mexico banned the use of ladder reinforcement for resisting shear forces in walls. It's kind of tricky the behavior of 'confined masonry'.
I think the code tries to simplify everything but due to some provisions the design tends to be overconservative [adding a vertical confining member [read: column] @ every 3m min. for ex.], especially how it's done, but then again you see cases like this building in ecuador and it makes you wonder why it's not being coded to be more conservative so at least when they half ass the construction they end up with a more proper looking building, at least seismically speaking.
