Releases between two beams element ABAQUS/CAE
Hi, I have a problem with Abaqus/CAE.
I have simple two element beam (in othes software (example Sap2000) I can define a releases, between end Node beam 1, and start node beam 2, for example to add and internal hinge.
is It possible with abaqus/CAE? if yes how?
this is the simple system:
http://files.engineering.com/getfile.aspx?folder=c...
Thanks in advance
Thanks in advance
RE: Releases between two beams element ABAQUS/CAE
If you want the change within one step, look here:
http://www.eng-tips.com/viewthread.cfm?qid=409879
I'am a new user in Abaqus.
can you give me an example for my case,please ?
in such a way that it can deepen the study . I did not understand the procedure from the link .
thanks in advance
I would be grateful if you could explain the procedure ;)
I'm sorry for the trouble ;)
THX ;)
