The problem with SQL after migrating the database to another machine
Having an odd SQL problem attempting to get a database moved from one machine to another. Both machines are running SQL 2008 32 bit and are both Windows 2008 servers. When I attempt to back the database up using the SQL tools and restore the .BAK file to the new SQL server, I get the following error:
Restore failed for Server “servername” (Microsoft.SqlServer.Smo)
Additional Information:
System.Data.SqlClient.SqlError: RESTORE detected an error on page (44:2097184) in database “RestoreDBName” as read from the backup set.
Likewise when I attempt to simply copy the .MDF and .LDF files to the new server and attach them, I get the following error:
Attach database failed for Server “servername”
An exception occurred while executing a Transact-SQL statement or batch.
A system assertion check has failed. Typically an assertion failure is caused by a software bug or data corruption. To check for database corruption, consider running DBCC CHECKDB. If you agreed to send dumps to Microsoft during setup, a mini dump will be sent to Microsoft. An update might be a vailable from Microsoft in the latest Service Pack or in a QFE from Technical Support.
Could not open new database ‘NewDatabaseName” Create DATABASE is aborted.
Expression: lfh->lfh_startOffset==startOffset
SPID:55
Process ID: 292876 (Microsoft SQL Server, Error: 3624)
From everything I’ve read, these errors generally indicate some sort of database corruption. However when I run DBCC CHECKDB on the database on the source server, it comes up perfectly clean... no corruption detected. In fact, this server hosts 8 different databases. All DB’s check out okay on the source server, however none of them will restore to a new server using either of the above methods. I’m having a hard time believing all of them could be corrupt when they show absolutely no indication of a problem.
Anyone have any ideas?
RE: The problem with SQL after migrating the database to another machine
Try doing the backup and restore via SQLCMD (or via a query window in SQL Server MS).
The backup would be as follows (obviously, change "MyDatabase" and "D:\BACKUPS" to whatever database and location you want to back up - just using for example):
BACKUP DATABASE MyDatabase
TO DISK = 'D:\BACKUPS\MyDatabase.bak'
WITH NOFORMAT, NOINIT,
NAME = 'MyDatabase-Full Database Backup',
NOREWIND, NOUNLOAD, STATS = 10, SKIP
Copy your backup file to the other server, and there do:
RESTORE DATABASE MyDatabase
FROM DISK = 'E:\Backups\MyDatabase.bak' WITH FILE = 1,
MOVE 'MyDatabase_Data' TO 'E:\SQLDATA\MyDatabase_Data.mdf',
MOVE 'MyDatabase_Log' TO 'E:\SQLLOG\MyDatabase_Data.ldf',
NOUNLOAD, REPLACE, STATS = 10
Again, change your names and locations to suit.
May be this article will give you more information.
http://www.techrepublic.com/forums/questions/it-se...
Sounds like common sense but make sure everything is updated properly (Microsoft products are you know what when they are not updated).
Silas, you need to respond, please.
Skip,
glassesJust traded in my OLD subtlety...
for a NUance!tongue
