Remove Orphaned dimensions and notes
Is there a way to remove all orphaned dimensions and note from a set of drawings? If I take a master assembly and remove parts from it I'd like the dimensions and notes removed without manually searching thru multiple drawings.
RE: Remove Orphaned dimensions and notes
In NX 9, you can delete all the annotations that have lost associativity on the sheet by going to preferences -> drafting -> general/setup -> retain annotations and pressing the delete retained annotations button.
www.nxjournaling.com
