Rotational Application - Bolting
I have an application that has 12 bolt in a rotational flange that has speeds up to 3000 rpm.
As the nuts are external, and have a relative weight to them, I have calculated the total bending stress in one bolt as around 500 N/mm2 - this is subject to a centrifugal force if the nuts move due to centrifugal forces parallel to the face.
As the bolts are stretched via torque, the combined stress in bending and tensile is approx. 725 N/mm2.
This the maximum condition @ 3000 rpm.
The material of the bolt is 750 N/mm2 Yield and the UTS is 840 N/mm2.
Would this be acceptable in your opinion?
The torque in the flange is driven by the shear area of the bolt.
RE: Rotational Application - Bolting
Can you post your calculations and a sketch of the joint please I'm not understanding how the bolts in bending.
I can see the bolts being subjected to shear during rotation but not bending.
Your bolts cannot bend to the side unless the centrifugal force exceeds the friction force due to clamping. You need them tightened down hard.
JHG
You need to determine the alternating and mean stresses in tension and shear and use some form of fatigue / failure analysis (such as modified Goodman) for the multi directional stresses.
There is some good stuff on Wikipedia and boltscience if you do not have a mechanical design textbook or machinery handbook handy.
ZCP
www.phoenix-engineer.com
I calculated that the centrifugal force could be greater that the frictional force on the nut face, hence the slight possibilty of bending.
I just did a sample calculation really quickly- for a 1/2 bolt rotating on a 12 inch radius at 3000 rpm, the radial force on the nut was about 115 lbs, compared to a bolt tension at proof load of approximately 6,000 lbs. Not even close.
