Help Needed Doing Vibration Analysis
Dear All,
I am doing Vibration Analysis of Box which is actually mounted in Railway Coaches, In which I need to check feasibility of Mechanical structure, which can withstand 3G shock in X, Y and Z Direction,
Any body has done the same?
appreciate your help and support!!
PS. This Box(under slung Inverter) is 3.0 mm Thk SS-304(Welded Box) with IP65 Protection.
Thanks & Regards
Asit Rathod
Thanks & Regards
Asit Rathod
