N m3 of a gas
N m3 of a gas
Is there a standard accepted definition for "N m3" when speaking about gases? I see conflicting information with some sources using 0 C as the reference temperature whereas others use 20 C.
Is there any widely accepted definition of the term?
RE: N m3 of a gas
This is why it is so important to state your standard conditions whenever you issue a calculation or specification. If someone issues a document to you make sure that you know what standard they are using.
Katmar Software - AioFlo Pipe Hydraulics
http://katmarsoftware.com
"An undefined problem has an infinite number of solutions"
RE: N m3 of a gas
Even if not universally accepted definitions, any idea if the industrial gas majors have agreed upon a definition? I was trying to look up the Praxair / Linde websites but did not find any guidance. In case it matters, this is for Hydrogen.
RE: N m3 of a gas
RE: N m3 of a gas
RE: N m3 of a gas
But one cylinder it doesn't.
Somewhere in the middle is usually a good point and the 15C / 60F and 1.01325 bara / 14.696 psia is usually my start point if no one has defined it and the odd decimal point isn't that important.
