Flow Indicator and Totalizer Notation
What would be the typical way to indicate on a P&ID a Flow Indicator plus totalizer?
Would it be a FIQ? Just wanted to check.
RE: Flow Indicator and Totalizer Notation
Yes.
Some would show it as two seperate functions such as FI and FQ or something similar.
Ashtree
"Any water can be made potable if you filter it through enough money"
Thanks for confirming that!
I usually see FQI rather than FIQ.
Thanks @danw.
I was always confused about the order of the modifiers. Is there any guidance about the order in the ISA specs. to decide which letter comes first?
The I for indicator or C for controller always seem to come last. This one in particular is on the list of typical identifiers:
