Chilled Water Piping System with Secondary Pump
Hi Guys, i have a question. Isn't it that in a close loop piping system is that we only consider the pipe and fitting loss + loss in chiller,fahu,ahu etc.?
How about in a close loop with a secondary pumping system? Can we add the static lift (Height) or still negligible? Kindly see attached file for your reference.
Your comments will be a big help. thanks
RE: Chilled Water Piping System with Secondary Pump
Usually a small fill / pressurisation pump is also included somewhere in the system able to do this occasional filling exercise.
