So what ever happened to this transmission?
Seems like another goofy idea that will not hold up.
http://www.overdriveonline.com/allison-to-produce-...
RE: So what ever happened to this transmission?
... which would not be surprising. I recall seeing section drawings of at least a hundred similar tilting-ball CVTs, few of which got very far past the first prototype. I'd guess that durability issues associated with contact stresses did them in.
Contrast that with the (VW?) steel belt CVT, the first one good for more than a few miles of use, and AFAIK the basis for most/all current production CVTs.
Mike Halloran
Pembroke Pines, FL, USA
Previous versions of this have failed at the contact point between the rotors and the ball or wheel. If you can solve that then they work quite well - low power ones are used in some electric motor transmissions for industrial installations.
Cheers
Greg Locock
Fallbrook calls its bicycle system NuVinci.
https://www.amazon.com/NuVinci-N360-rear-hole-silv...
Cheers
Greg Locock
Edit I remove "and" after Gee.
It's like the wankel engine, it seems to have some significant benefits but has one major point of difficulty. Solve that and you are quids in.
Cheers
Greg Locock
durability is the main problem, and also lack of suitable lubricants for this specific purpose. the power transmitting balls need to be lubricated to prevent excessive friction and at the same time when torque needs to be transferred the lubricant more or less needs to freeze in place stopping momentarily when the lubricated mating parts need not move relatively to each other. that calls for a socalled traction fluid where the viscosity temporarily can go very high if enough pressure is applied.
various oil companies work on developing suitable fluids, with only limited success so far. for the Nuvinci bicycle drive a naphthenic oil is used - the viscosity rises quite a bit more then with the paraffinic or synthetic baseoils used in most modern lubricants when pressure is applied.
Valvoline partnered with Fallbrook to develop a traction fluid (Invaritorc 638) specifically for their small CVT drives.
