Modelling a bolted interface
Hello!
I think the title is a good summary!
I have a region on my design which has a interference fit bush, which I modelled with RBE2.
The first question is: is it accurate to model it that way?
Secondly, by running a non linear static, would having a RBE2 create inconsistent results? I remember that RBE2 are not updated in the stiffness matrix for SOL106 in Nastran. Is it true?
Many thanks for your support all!
Pat
Pat
RE: Modelling a bolted interface
If you plan to run a NonLinear analysis using NX NASTRAN (SOL106) then better forget the use of RBE2 elements, see the limitations:
• Rigid body elements (RBEi, RBAR, RROD entries, etc.) do not rotate in geometric nonlinear analysis.
To model interference fit, better define explicitely the contact interference and solve as a contact problem using linear static solver of NX NASTRAN (SOL101), take a look to my BLOG in the following address:
https://iberisa.wordpress.com/2012/01/16/tratado-c...
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48004 BILBAO (SPAIN)
WEB: http://www.iberisa.com
Blog de FEMAP & NX Nastran: http://iberisa.wordpress.com/
