Title block in Solid Edge
I am working on a .dft file in solid edge and I have gone to the background tab under View and set the Title Block details for all sheet sizes there in the four tabs A4-Sheet, A3-Sheet etc.
But when I return to the working drawing the Title Block details don't reflect there. If I print from the Working Drawing I get the default details in the title block. If I print from any of the other tabs I get the right details in the Title Block but an empty drawing.
How can I fix this?
How can I fix this?
RE: Title block in Solid Edge
I think right click on the working sheet tab to bring up the window you need.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
