External Force on Tank Shell
thread1452-332421: Max allowable loads for brackets on tank shell
I am designing a platform support bracket which will attach to a thin-walled tank. Can anyone offer alternative methods other than the one's listed in Soln's post referenced above?
Soln, were you ever able to find a credible source for an alternate design method?
Thanks in advance!
RE: External Force on Tank Shell
Bednar's pressure vessel book includes methods for circular pads/plugs and for line loads on tank. I would think both are pretty approximate, although it is more obvious with the second one.
Perfect, thank you!
