STAAD Crashing
STAAD Crashing
I have an older version of STAAD. For the past few months it has been hit or miss in regards to getting through an analysis. Is seems about 30% of the time it is crashing. I'm not entirely sure, but it might only occur when I am attempting to do a direct analysis method. Is anyone else having problems? The solution is to probably update the program but that is going to cost a ton of money to get something that I shouldn't need.
RE: STAAD Crashing
RE: STAAD Crashing
I took a screen capture of the error and the text file from the analysis (which are attached below MS word document). It is completely random whether the model triggers the error or not. If I run this model again it might make it through, it might not. The error started popping up a few months ago. I am using an older version of STAAD (V8i I think).
RE: STAAD Crashing
RE: STAAD Crashing
RE: STAAD Crashing
RE: STAAD Crashing
RE: STAAD Crashing
RE: STAAD Crashing
I ran it again on within the backup file and it failed to make it through the analysis on the second try. Attached is the file.
