RESTART FILE MODAL DYNAMIC
Hi everybody!
I performed a modal analysis in a previous job and I want to make a restart input file in order to make a modal transient analysis on the same structure with the *MODAL DYNAMIC
In my modal analysis input file I wrote before the *END STEP: *RESTART, WRITE and a t the beginning of my transient modal analysis input I wrote: *RESTART, READ.
The pb is that when I run my analysis via UNIX my analysis stops, I don't have any error message in the .dat or .msg just a message in the file abaqus.number_of_the_job
Run standard.exe
! An unhandled exception occurred !
The error is : <CATInternalError 1 CATSysFatalERR_000001>
Environment incorrectly set : environment variables CATErrorLog or CATTemp must be set in order to obtain statistics files
I have absolutly no idea where it comes from...
If the community has an idea I will take it...
Thx in advance
RE: RESTART FILE MODAL DYNAMIC
Anyone...?
I saw that modal dynamic was incompatible with restart, write but it is possible to read the frequency input file btw?
