Helium test for tube exchanger
Dear Sir,
I try to find out about criteria of selection method for testing leak , could every one tell me about when we select helium test method
for tube of exchanger?
BRG.
SK.
BRG.
SK.
RE: Helium test for tube exchanger
You can reach out service company (such as Conco) and ask them about leak testing.
You can do it on tube-to-tubesheet joints, but entire HX (especially in service) tend to have way too many leaks to make He practical as your first leak test. Even if there is a He test requirement people often test with something less sensitive first, fix the big leaks and the re-test.
songkarn, it really would depend on the materials used and design requirements
r6155
SK.
