Salt building construction joint filler
Hello. I am designing the foundation and walls for a small salt storage shed. Any suggestions for a brine resistant filler for the slab joints? Construction joints in this case, not control joints. I am also specifying stainless steel dowels for load transfer. I was thinking of epoxy coated dowels but if anyone has real life experience as to how these hold up against corrosion I would like to hear your opinion.
Thanks, Engingguy
Thanks, Engingguy
RE: Salt building construction joint filler
The joint filler is to help contain the brine. Neoprene joint filler perhaps?
If you do need to seal the joint, a major supplier of concrete joint products is W. R. Meadows Company. Their technical support reps can probably suggest a suitable product.
See this article in the current (June 2016) issue of Structure Magazine for a discussion of the pros and cons corrosion resistance rebar: Steel Rebar Coating For Concrete Structures
If you decide to go with stainless, 316 or 316L are more resistant to chlorides than other commonly available types.
www.SlideRuleEra.net
www.VacuumTubeEra.net
This shed will be near to a stream and I am taking an extra step or two to control seepage of contaminated water. Of course, all that salt will be spread on the roads nearbY anyway.....
This is a good forum. Thanks.
Richard A. Cornelius, P.E.
WWW.amlinereast.com
WWW.amlinereast.com
All joints probably require routing out to constant width and then blown clean so no dirt is in the way.
I've got this hang up on the beeswax - realized this is also "snow seal" that we used to weatherproof everything in the N.W.
