Regardin boolean operations
Hai every one,
i have a problem with boolean operations.when i'm trying to ADD two part bodies, it is not perform the boolean operation. it showing "Topological operator:internal error".I dont know why it is happening can anyone suggest what may be the causes?
RE: Regardin boolean operations
An image of the two bodies or might be helpful in identifying a cause if you are able to post one.
--Doug
