UBC references don't make sense
Im reading through the 1967 UBC Chapter 25. Page 161 reads:
"MACHINE STRESS-RATED LUMBER, is lumber which has been individually pretested by an approved nondestructive mechanical means supplemented by visual grading as required in UBC Standard No. 25-1-67, Section 25.113 ...."
Where on earth is Standard number 25-1-67 and Section 25.113? Are these in another document called UBS Standard? because I sure can't find them in the 1967 UBC. The sections aren't even labelled like that. They're more like Sec. 2503, Sec.2504 etc.
RE: UBC references don't make sense
In 1967 they may have been published as a separate set of documents rather than in the back of the code book....not sure.
