Chinese steel section properties
I'm working on to additions to a project in the USA that has steel shapes from China. I see shapes designations like HN500, HN446, HM440. I'm looking for a website that will give me section properties for the Chinese steel. I would like full properties such as A, Ix, Sx, Rx, etc. Any assistance would be appreciated.
Rich
RE: Chinese steel section properties
You may find some useful info in one of my former threads: Link. Stuff I learned:
1) Size proportions can be quite different.
2) Quality control can be quite different.
3) Where Fy is different, b/t ratios change which apparently has something to do with why proportions are different.
For your sake, I hope that you're working with US shapes rolled in china rather than true Chinese shapes. It was pretty painful getting it all sorted.
Unfortunately they are true Chinese shapes. The drawings show a mix of traditional USA wide flanges and Chinese shapes. My new structure will be supported on both so I need to check capacities of each. That is why I need section properties of Chinese shapes.
The drawings state the Chinese steel is ASTM 992.
what software are you using? Staad has Chinese properties. Risa probably has it also
Thanks for the link. Being from the slide rule era you appreciate a good printout of the document. Unfortunately the PDF is a no-print documents. Thanks anyway.
I don't use STAAD or RISA. I use Bentley RAM Elements. I did not see Chinese shapes in my data base.
Use software to take an image of the pdf, then print it. Sometimes these are a little fuzzy, but they work.
That's what I ended up doing.
Thanks.
