Hi I'm trying to find a cheap solut
Hi I'm trying to find a cheap solution for a galvanic separated point to point RS485 bus. I need to send data between these 2 points in 1/2 duplex. There are full solutions for it like the www.linear.com/product/LTM2881 however these are very expensive and I would blow my complete budget on these babies.
There are some other standard solutions with opto couplers and a 2nd power supply however I don't like these either.
I came up with this idea (more or less based on the old appletalk or local talk as it was called I believe.) using 2 pulse transformers on both ends of the line.
I'm going to use manchester coding at a 100Kbits/sec data rate.
My question anybody any better ideas/suggestions?, any people having experience with this kind of set-up?, any advice type/model for the pulse transformers? my budget is max 2€ per point to point link on materials.
so including resistors, capacitors schottky diodes etc Excluding PCB, design costs etc.
All help/pointers welcome.
Thanks Jan Z.
Thanks Jan Z.
RE: Hi I'm trying to find a cheap solut
TTFN
FAQ731-376: Eng-Tips.com Forum Policies forum1529: Translation Assistance for Engineers
TTFN
TTFN
Dan - Owner
http://www.Hi-TecDesigns.com
PS. "Dan" don't what your link means I can't open it?
comes to less than $1/each
TTFN
But with a 10 lower frequency would mean a lot more phase difference and with capacitors on both sides of the cable would that mean doubling the capacitor size.....Wonder if it would work.... Food for thought All comments welcome!
Z
