Vertical Slide Clip for Wood Studs
Why is there not a widespread product for a vertical slide clip to attach wood balloon framed walls to floors? This connection is very common in the metal stud industry.
RE: Vertical Slide Clip for Wood Studs
Why not widespread... only opinions prevail. I think since wood is used so much for residential their is layers of unaccounted load sharing where non-bearing walls are loaded and clips cost money. plus they have been building that way for 30 years and haven't used them yet...
Mike McCann, PE, SE (WA)
But yeah, Balloon framing is a lost technique and usually only specified as a deliberate situation/config where it is unavoidable. Long and straight studs are not in the lumber yard for a good price.
I guess it leads to a curiosity question: why are you balloon framing? 20'-26' not too unusual a span at 14"-16" joists (More than that and I am using trusses). With longer spans I would want the platform framing anyway I would think just from a logistical and safety standpoint if I was the framer. Maybe you are doing something we don't consider normal. My understanding a vertical slide clip is used where the floor is structurally independent of the wall and the wall is backed up by the floor -a la curtain walls. Don't see that in light frame wood structure much.
______________
MAP
