Catia Product constrains numbering order......
When I add constrains into a Product, sometimes the numbering do not starts from 1 (please, see the attached picture).
How could I correct that?
CAD 2015
RE: Catia Product constrains numbering order......
No attached picture. Anyway, that means you already put some constrains and deleted before, CATIA is keeping the counter in memory, doesn't meter if you don't see them. You will need a macro to renumber them (I don't remember if v6 knows to renumber but I believe yes, it has this functionality without any macro)
Fernando
https://picasaweb.google.com/102257836106335725208 - Romania
https://picasaweb.google.com/103462806772634246699... - EU
Thanks Ferdo.
I think that my company placed a filter.
Or my account has problem........
I did download a picture! I can't upload any image anymore!
CAD 2015
Ferdo,
How could I create the macro to renumber the constrains?
Can you direct the steps, please?
CAD 2015
You can try something like this:
CODE --> vba
Sub Main()
    Dim doc, prod, constr, i
    Set doc = CATIA.ActiveDocument
    Set prod = doc.Product
    Set constr = prod.Connections("CATIAConstraints")
    For i = 1 To constr.Count
        constr.item(i).Name = "Fix." & i
    Next
End Sub
Tesak
http://scripts4all.eu/txtoncurve/ - Curved text for Catia V5
Thanks Tesak!
CAD 2015
If this is the most of your worries... he he
Tesak,
Your script didn't work........
CAD 2015
I have tested it and it is working, so something is wrong on your side. Share your code and we can check it.
Tesak
All scripts must contain CATMain function as a starting point. Rename Main into CATMain and it will work.
Tesak
It works, but see the attached file.
It is curious, all constraints have been converted in "Fix" one....
I used this script:
Sub CATMain()
Next
End Sub
CAD 2015
I gave you this code just as an example how to get a contraints collection. Of course renaming algorithm has to be changed according your needs. You have to count number of contraints of a specific type and replace existing numbering with desired one.
Tesak
OK, thanks!
CAD 2015
